Transmission problem, need help.....
    I did my H22 swap on the wagon and now i have a problem with my tranny.
    I put a 8 pounds flywheel, Exedy stage 2 clutch.
    Problem; When i start the car in the morning or when its park all day the tranny shifts good & normal, the pedal adjustment its low. But after 15 or 20 mnts after the clutch start messing up, i stop and the pedal on take off its all the way up, the car on gear revs a lot and barely moves, like when the clutch its gone. But after letting the wagon sits for a while start working fine again.
    I dont think its the clutch cause if its bad it will do it all the time cold or hot, check the slave cilinder, line, clutch master cilinder and all good.
    Any advise or WTF its wrong here?
    bump, some 1 will help soon
    how do your brakes feel? fine i assume. i ask cuz if everything else checks out fine, can be a prob with master cylinder.
    since you had this prob, how many times did u bleeed the clutch?
