whats the best plug for mpg because i was getting 22-24 now im getting 19 im thinking i have a dead plug so was gonna replace them all but i did not know what plug to get can yall help me out?
best spark plug for mpg?
MSD wire i have on my h22a, And i get really good gas miles on them
No need to go platinum unless you have an upgraded ignition setup. You won't be getting the full potential of those plugs. It would be a waste of money. Go with Standard NGKs' or Bosch plugs.
I think some people are using Denso and E3 plugs on this forum as well.
CB7Tuner Resident Gamer!
PSN: JDMcb7TX
ok not getting the iridums this time next time i will but im geting the ngk plat for 2.99 at autozone
http://www.autozone.com/autozone/par..._&sortType=low
Why run platinum plugs on a stock f22 motor? I know it's cheap, but it do u any better than regular zfr5f-11 plugs. Just changing you plugs will not get you better gas mileage. Your normal tuneup and valve adj., etc. I work at the dealer so I believe in only Honda parts.
for your buck.IMO.
