Where does the main Alternator wire run to?
    I have been having a short in my electrical systems for over the last two months. This was due to my alternator wire running next to my timing belt and was getting chewed up and has damaged the wire. I have since fixed the damage but I am still getting this flickering in my headlights, guages and just about everything else inside the cockpit. I would like to know where it runs to so that I may rewire where this goes to. Thanks in advance!
    Happy
    The CB7 Collector.
    Team Kindred Impulse Member #3
    92 LX Coupe F22A1
    2013 Toyota Corolla S
    92 EX Sedan F22A1
    Do you really need to make a thread asking if having your car like this /---\ will cause uneven tire wear? Try walking like that for a few weeks and see if your shoes wear funny! (hint: they will.)
    main wire goes directly from the alternator to the fusebox. it is the second screwed-down wire attached to the front of the box.
    it is loomed into the main engine harness, but it makes no other connections. you can replace it with an external wire with no problems, just make sure the ends you use are attached very firmly, soldered preferably.
      Sweet!! Thanks now replacing this should be much easier !
      The CB7 Collector.
      92 LX Coupe F22A1
      92 EX Sedan F22A1
