h23 rods in a f22b dohc?
    so i was doin a little research.and i was wondering if the h23 rods and crank would fit in a f22b dohc.the reason is i have a spare h23 blockand i want the piston to come out of the block like a stoker kit...is it possable?
    my new turbo build
    It would come out of the block all right, and thru the head
    Originally posted by lordoja
      that far huh...even with my stock pistons?but according to this there the same.so what gives the h23 the extra liter?
      http://www.cb7tuner.com/vbb/showthread.php?t=41915
      my new turbo build
        F22B = 85mm bore
        H23A = 87mm bore
        H23A has FRM sleeves that enable a big bore. U can't, AFAIK, safely bore an F22B block to 87mm.
        U have the H23A block... ur good, just get
        - stock H22A pistons
        - H23A/F22B/F22A rods
        - H23A crank
        H23A displacement, H22A compression, just need to make sure u have enough valve clearance and all that shi
          Originally posted by gloryaccordy View Post
          F22B = 85mm bore
          H23A = 87mm bore
          - H23A crank
          ok so the 87 mm bore give it a extra liter...dont think so/really never new that...i wanted to put the h23 bottom rods and crank in my f22b and keep my sstock pistons..to make it a f23b dohc for a lil more torque..but the rod lenght and cranks are the same as the f22b dohc so it would be no point..and i was asking,what gives the h23 that extra liter?
          my new turbo build
            The H23A & F22B have the same crank, swapping cranks between the two will not gain you anything, you need to brush up on engine dimensions & learn the difference between the two. IIRC the only thing different is the pistons and you can't put H23A pistons in an F22B w/o sleeving
