Problems installing tps sensor
    So i ordered a new tps sensor cuz the cb i just bought idles very rough and bounces from 1000 to 2500 when idling, and to my dismay i find that its riveted in. is there an easy way to remove the rivets or do i have to replace the entire throttle body? thanks guys
    1992 Lx Sedan, b18 obd1 swap (swaping trans)
    1993 Ex Sedan, f23 sohc vtech swap (totaled by an excursion )
    1991 Ex Coupe (New Daily Driver)
    1984 300zx Turbo (drift car)
    Take a dremel or saw and cut a notch in the top of the "rivet". Then you can use a screw driver to take them out.
      Are you sure it's your TPS and not the other, more common failures that result in the same idle problems you have?
      Originally posted by DoctorCipher
      ...the beginner forum was created to provide a place for all the stupid ass questions to pile up and fester, kind of like huge globs of mayonnaise left in the sun for weeks at a time.
        When you replace a TPS, it must be recaliberated if Im not mistaken.
        www.PreludePower.com
        BB SQUAD MEMBER #28 V.2
          Don't think it would be the idle air control valve ?
          Maybe some carb cleaner and some adjustment, you can fix it.
          -1992 CB7 EX w/H22 [sold 10/09]
          -2005 Legacy GT limited [current]
            who told you to replace the tps?
