I swapped a F22B in my car about a month ago. And since then I hear a weird noise. It's sorta like something that turns without oil or smth. It only does it when i'm going at a certain speed or i should say at a same RPM in any gear. I'm thinking Wheel Bearing. The Motor Mounts are ok we checked them. It only does it when i'm riding. Weird. I thought that wheel bearing would always make noise whatever the speed. But i'm thinking that maybe i just hear it more at this speed or smth. Dunno. What else can it be? Transmission (i had the clutch replaced too) or Diff? My car had none of those noises before the job.
If anyone has any idea tell me. I guess i will have to put it on a lift and make it run so i can see and hear where it comes from.
