im not sure what this little black box beside my battery is. when i put a cai on the motor it lost the vac lines.its on the left side
whats this part?
um, for real you can use it as an iab? I always thought it was as mrhonda said, a silencer that limits intake at low rpms to reduce engine noise. I've been desperately trying to get an IAB but no one seems to have one. Since I swapped out my stock air box with a CAI, I have my little black box left over. Can anyone confirm it can be used as a replacement for the IAB?
i think cb9 is a little confused or read it wrong, its not the IAB box that is under the itnake manifold. its the one next to the battery that is worthless..H22 Prelude VTEC 92-96 200 161 10.6:1 87 90 DOHC VTEC 2157 JDM
if he's refering to the box, next to the battery w/ the vaccum cut switch. than i'm right. now if it's the big ass box behind the fender liner. than i'm wrong. i've got my 2nd runner actuator running off that, and it works. i found it opens @ 4800. try it, hook a vacuum line to it, run the idle up on the motor, poof, @ 4800ish it cut the vacuum.
^^ Thanks, smartass. ^^Former: 90 Accord EX Coupe, 93 10th Anniversary in Frost White
1985 Volvo 245 manual [IPD lowering springs, IPD sway bars, OEM Virgo wheels, 1977 quad round headlights, 1978 grill]
2001 Mazda B3000 SE 4x4 extended cab [stock except for CB radio]
2008 Ford Escape XLT [bone stock]
2015 Toyota Prius Three with solar roof [rear diffuser, Vision Cross wheels... cheaper than steelies!]
My haynes manual claims it closes at 3500, anyway I installed it today, and I confirm that it does work! The old method of straight to the manifold does close them, but I could never confirm that it opened them back up. Anyways, I reconfirm that this method works!
