Hello, all. Once again, I have a few questions. This time, relating to a blaster coil, and a performance chip.
First off, I seen a P. chip I could get for my cb7 that plugs into (I think...) the air intake plenium, that is supposed to tell the computer the air coming in is cold, and increase fuel flow. The seller said w/ an intake, you run a little lean (which he's right, I already knew this much...), and that the chip is supposed to compensate for that. My question is, will this P. chip help as much as I've heard it will? And, I've been told if I got one, I may run a tad rich and need a bigger coil, which I planned on getting anyways.
Next question, if I get a MSD Blaster Coil, will I have to also get the dis. cap to go with it? And, will I need better wires, or will the stock style ones work?
Thankx for all your help and replys!
