I know all the basic stuff, timing belt, water pump, balance shaft belt and what else do i need to replace? What is the most important, i have 500 dollars to get this stuff done so i need the most important things that need to be done. Please help.
What to replace doing timing belt?
I'm going to be doing this soon too. Here are the parts I have accumulated in the past few weeks. The top ones with part #'s are genuine Honda parts. I'm also doing the lower spark plug seals while in there. and, replacing the valve guide seals.
PART LIST
14400-PT0-004 TIMING BELT
13405-PT0-004 BALANCE BELT
91233-PT0-003 BAL SHAFT SEAL
15114-PT0-003 OIL DRIVE GEAR SEAL
91212-P0A-004 FRONT MAIN (CRANK) SEAL
91213-PT0-003 CAM SEAL
12341-PT0-000 VALVE COVER GASKET
19200-P0A-003 WATER PUMP
rockershaft seals(lower spark plug tube seals)
balance shaft seal retainer
Honda coolent
PS belt
AC/alternator belt
By the way there has been a couple threads started on this, look around.
