Decklid & Trim Question
    Synapsis: So a few months ago I got rear ended by a 99' Tacoma. Nothing really happened to my car other then a few scratches, bent exhaust and muffler. I replaced the deck lid and I found hidden damage. My left taillight and the white trim piece just below the tailight (the outside one not actually on the trunk lid) was pushed inward. So my question is, how hard is it to replace that trim piece? Also, the rail for the trunk lid is slightly bent? Easy to bend back or just go to a U-Pull and pull another rail? Any help is appreciated
    Mods: Wasn't really sure if this would fall under Appearance or Technical.
    There is two 10mm bolts that hold that trim in.
    if your rail is bent, you will need to get it on the frame straightener and get it straightened out.
      Word, thank you!
      You going to the accorn lude meet tomorrow?
