Need torque specs
    Need torque specs
    Im currently putting a new head on a new f series block, i need the torque specs for that, and also i need information on how to time it, i know the #1 piston needs to be up but can someone give me detail on these two things please
    go to a parts store and pick up a haynes manual. keep it in your toolbox. It has almost all the info you will need.
    Life's a garden. Dig it.
      i know that. im trying to save some money. which is why i asked on here
        Follow the sequence, but heres the tq specs
        step 1: 29 ft lbs
        step 2: 51 ft lbs
        step 3: 72 ft lbs
        http://repairguide.autozone.com/znet...528018f66a.jpg
        To find TDC on the bottom end use the crank pulley the white mark is TDC the red marks are for the base ignition timing, which you will need to set by jumping the service connector have a timing light an adjust it from the distributor.Before you get to the ignition timing you will need to make damn sure your bottom end is at TDC aswell as the cam gear.Hope this helps GL.
        02 Crv
          he means the head bolt tightening sequence, if that isn't clear.
            Actually, straight from Helms manual the cylinder head screws are:
            29 lbf
            51 lbf
            78 lbf
              29 lbf
              51 lbf
              78 lbf
              yes but in what sequence like tighten bolt #1 then #2 and so on
                Just double checked my "Bible" hiltons Import 90-97 manual part#7290 has almost all imports including porche its ike 6 inches thick....Has never let me down an i was on the money tq wise an autozone sequence is correct aswell.Never liked helms anyway both specs are pretty close expect the final step of Tq'n oh well.
                02 Crv
