Speedometer bounces around then stops working
    Car: 92 Accord Lx F22a1 manual trans.
    Symptoms- Once car has been driving for about 30 min the speedometer will start to jump around from zero to whatever speed I am at. It does this for about 10 min, then the speedometer stops working completely. Within a few minutes of the speedometer failure the check engine light comes on and the car idles high.
    I am thinking either something in the cluster, the vehicle speed sensor, or even the ECU. Any ideas ?
    Originally posted by HardInThePaint
    WTF, thats like placing the cheese underneath the beef patty and calling it a burgercheese. Regardless of how u slice it the shit is a cheeseburger.
    it is most likely the speed sensor, because the CEL comes on. to find out for sure: http://www.cb7tuner.com/vbb/showthread.php?t=21259
      That was my first thought. I figure the idle is off because the computer is not getting an accurate reading so its not mixing fuel and air properly.
        I have been under my dash for hours, no little blue wire anywhere. Should it be plugged into anything ? Help please, I don't want to spend $100 on a VSS if that's not it for sure.
          I had the same issue too awhile back, my issue was that the two little plugs under the dizzy that hook in the sensor on the tranny had become disconnected a little bit. May or may not help you, but it's somewhere to look. But i never got a CEL
