So my 97 JDM H22a has a problem where it will start up run really rough and then die. So my quuestion is would this be caused by my map sensor maybe being bad or would it be something else? Already checked the wiring and other sensors (except for the map sensor) to make sure everything works. Any help would be appreciated cuz i am stumped.
Map Sensor Question
are you getting any check engine light codes? have you checked fuel pressure? check spark?Originally posted by phantomcb7 View PostSo my 97 JDM H22a has a problem where it will start up run really rough and then die. So my quuestion is would this be caused by my map sensor maybe being bad or would it be something else? Already checked the wiring and other sensors (except for the map sensor) to make sure everything works. Any help would be appreciated cuz i am stumped.
1993 CB6 Coupe Seattle Silver YR-94M
yeah its verse 10.6:1Originally posted by Acclude4gens are win. It's in the bible somewhere.
Members Ride Thread
1993 Accord Coupe- Summer ride
http://www.cb7tuner.com/vbb/showthread.php?t=130064
1995 Civic Coupe - Winter/DD
http://www.cb7tuner.com/vbb/showthre...53#post2744953
have all plugs with spark and fuel but it just came up with code 3 yesterday so i guess i shall be replacing the sensorOriginally posted by 90blackcoupe View Postare you getting any check engine light codes? have you checked fuel pressure? check spark?
