just threw a rod in my f22a6. is the head still reusable? or done deal?
reusable head?
It depends on if there was contact between the head an piston.Pull the head off an check it for damage.
02 Crv
Bent valves,cracks in the pistons,Dents on the surface of the head.Should be real noticeable as far as the dented surface of the head go an cracked or dented pistons(this will lead you to piston to valve contact or piston to head surface period).Sometimes bents valves are noticeable sometimes they are not.Just take her head off an check it over real well an possibly have it pressure checked if you ruled out everything else.
02 Crv
Yea you can use any F22a or b block an be just fine.But an F22a1 will do just fine for ya.Last edited by SOHC-FTW; 07-05-2011, 05:38 PM.
02 Crv
RIP 4/23/12
...lets not forget, the 88" Z31 turbo, are my dailys
