Hi, my clutch pedal "grabs" almost out and i wonder if this can be adjusted on the clutch rod? The clutch is not worn out or anything but this is no annoying
if you are in fact CERTAIN that the clutch disc is not worn...
...then take a look at this picture:
because you are actually looking to LOWER the clutch engagement point, then you need to rotate the shaft the opposite direction than what is shown in the picture (blue arrow). the rest is the same.
