Timing Belt Replacement: Parts
    I'm planning on replacing my timing belt in the coming weeks, but I'm not sure what parts I'll be needing. I'm planning on using all OEM Honda parts, regardless of price. So far, I've compiled this list:
    Balance Shaft Belt
    Balance Shaft Belt tensioner/adjuster
    Balance Shaft Belt shaft seal
    Timing cover seals (to fix the nonstop oil drip since 2001)
    Timing belt
    Timing belt tensioner/adjuster
    Water pump
    Water pump gasket
    Water pump seal
    What else will I be needing for this job? I'll likely have a nearby tuning shop install the parts, so tools are not a problem. Thanks in advance.
    Original-Owner 1991 Honda Accord
    2005 Acura TSX 6MT
    2010 Mazda Miata Grand Touring
    *sorry i was thinking of the balance shaft retainer clip so that seal doesn't "walk" out of place and cause a major oil leak.
    here is the part number 06923-P0A-306 it should only be a few bucks but it'll keep the seal from "walking" out of place.
    Last edited by Leung; 09-23-2011, 10:37 PM. Reason: balace shaft not cam shaft retainer clip
      Balance shaft retainer. Might want to do the front main while you're in there. Also you culd replace the tensioner pulleys.
        Originally posted by Leung View Post
        might as well throw in a cam shaft seal retaining clip.
        Could you point out what that is in the diagram I posted above? Sorry for the trouble; I'm still learning.
        Is the balance shaft retainer #13 on the diagram? And what is the front main?
        2005 Acura TSX 6MT
          Balance shaft seal retainer you won't find on the diagrams. The pn is on the second post here:
          http://honda-tech.com/showthread.php?t=2322260
          Front main is number 30 here:
          http://www.hondaautomotiveparts.com/...-+OIL+STRAINER
            What do you mean retainer?
            don't you just mean replace the cam seal itself which is 30 on the diagram above?
              throw in the water pump and the timing belt and the balance belt as well sh*** throw in the P.S belt and AC belt
              just a few things im going threw the same stuff now smh
              91 lx that I call Cinnamon
                Thanks for the input, guys. I'll build a compiled list and post it on here after I've ordered everything.
                2005 Acura TSX 6MT
                  Don't forget a Honda belt for peace of mind. I have never replaced a balance shaft belt on anything. Mine had 250k on it and it was still in ok condition.
                    i replaced my balance shaft belt even though it looked good because i now know that my timing belt and balance shaft belt have the same mileage/time on them
