Brake upgrade questions
    So I want to upgrade my brakes.
    Can I use accord v6 calipers and caliper brackets with 91-93 wagon rotors?
    If so will the calipers and caliper bracket have to be off a 5th or 6th gen?
    Are the wagon rotors the same as the 5th gen v6 rotors?
    Green EX http://www.cb7tuner.com/vbb/showthread.php?t=176536
    93 SE http://www.cb7tuner.com/vbb/showthread.php?t=210486
    All I can answer confidently is that the Wagon calipers are the VTEC lude calipers, and The wagon rotors are HOR.
      Hor?
        Hub over rotor
        COUPE K24
          Well all accord's and cl's and prelude's are
            Not cl's. Those are roh
            COUPE K24
              Correct. You use CL hubs, VTEC Lude calipers and rotors for 4 lug ROH conversion.
                but cant we use them?
                  See my post.....
                    I dont want to do a roh conversion, Just bigger brakes.
                      Well Im using Wagon/VTEC Lude calipers, 25T brackets, Wagon rotors, and CB7 hubs. So I get 11" rotors and bigger calipers/pads, but I retain HOR.
                        I looked up the part numbers and the 5th gen accord v6 rotors are the same as the 91-93 wagon rotors. So I take it the calipers are the same to.
                        What is a 25t bracket off? Will it be on any 91-93 wagon or 5th gen v6?
                          .... Wagon/VTEC 'Ludes....
                            Not a 5th gen accord v6?
                              Arent they 23T? But honestly I can't answer that one.
