Abs
    Abs
    I used to have an intermittent abs light come on in the dash. I was told it was something to do with the sensor being uneven with the axle ring. Anyway I got the wagon trunk organizer and while installing it I found that the abs control unit was in the way so I unplugged the battery then unplugged the abs unit and relocated it. Plugged everything back hooked up the battery and now there is no light. At all not even when I turn the key before starting the car.
    I'm afraid I might have busted the unit in the process of moving it. Could it be possible to have a broken unit and no warning light in the dash? Or could it be the dash light went out ( which I find unlikely) any ideas?
