Well I found a deal I couldn't pass up. I found an 07' Civic Si Sedan Catback with muffler and B pipe w/ resonator w/ only 49k miles on it. I want to incorporate this onto my coupe somehow.
How would you guys fit this onto the CB chassis? I know the resonator will have to be relocated, most likely to the straight portion of the pipe. Or I might need a whole new B pipe made with the resonator welded on. I think the muffler might need to be extended a bit as well because when I tried test fitting it, it seemed short about 3-4 inches.
Resonator measures 5" diameter by 16" in length. Muffler is 12" long by 10" wide x 8" high. The tip even looks pretty sweet, fills the CB7 rear cutout nicely.
But here it is:
But here it is:
Or is there some trippy optical illusion?
