Stripped out VC stud
    Hey guys and gals just what the title says. My valve cover stud is stripped..is there a trick to getting the studs out of the head to replace them? Needing help. Thanks
    "If you're going to put money into a car to increase performance or appearance, why go cheap? People don't need to go all-out... but put a little effort into it, or don't bother doing it at all"-Deeve
    Ride http://www.cb7tuner.com/vbb/showthread.php?t=187088
    Once you have the valve cover off you'll see a hex portion on the shaft that will allow you to remove it. Just get one from a junkyard and a few others for spares. It goes back in the reverse of removal. Don't over-tighten them.
      Just take the bolt/stud out and replace it.
      The fist one is the front and the last one is the back which part you strip
      STANCE|WORKS
        What if I were to just buy new SS bolts or allen head bolts to replace them all?
          Unless you can get the bolt made the way those are it wont work. The front ones also hold your rocker assembly to.
          STANCE|WORKS
            I'm not sure why that would be "devious" but it would be more effort than it would be worth.
              O ok, I understand. Ill get a few of those studs when I go to get my parts from the junkyard this next weekend Thanks guys
