Trying a new fluid for MTF
    I'm going to run Mobil 1 4t 10w40 in my accords transmission.
    Background:
    I just got the engine/transmission swapped. old one spun a main because I didnt fix a fuel issue on it(bad injector). Old trans had roughly 220k on it, shifted well, I had been using Amsoil MTF in it for about 20k miles. - saddened me to drain it
    Had a Clutch Masters Aluminum flywheel for like 4 years now, Finally got it installed since I was in there LOL.
    I know its always something people are looking for (MTF alternatives) so I figure I'd throw this out there. I chose this over 20w50 Vtwin because its a little closer to 5w30(honda mtf weight) and still has substantial ammounts of Zinc. Its also for use in "wet clutch" applications, which in my thoughts, **should** help with the friction needed for synchronizers to work correctly.
    I don't care if I waste 20 bucks on this, someones gotta try.
    Infored was what i didn't choose)
    Mobil 1 Motorcycle Oils Racing 4T V-Twin Engine/Application Type 4-Cycle 4-Cycle
    SAE Grade 10W-40 20W-50
    Service Classification API SM,SL, SJ,SH,CF,JASO MA API SJ,CF,JASO MA
    Density, g/ml @ 15.6°C (ASTM D4052) 0.86 0.87 Flash Point, °C (ASTM D93), 212 214
    Pour Point,°C (ASTM D97) -45 -42 Kinematic Viscosity, cSt @ 40°C (ASTM D445) 82.0 172.3
    Kinematic Viscosity, cSt @ 100°C (ASTM D445) 13.1 20.8
    Viscosity Index 161 142
    Cold Cranking, cP (ASTM D5293) 4,640 @ -25°C 7,500 @ -15°C
    Pumping, cP (ASTM D4684) 11,700 @ -30°C 14,000 @ -20°C
    Zinc levels
    Mobil 1 4T 10w40 1300 PPM
    V-Twin 20w50 1700 PPM
    Honda's MTF has around 1300PPM zinc
    Information sourced from here
    http://www.mobil.com/USA-English/Lub...ycle_Oils.aspx
    http://www.mobil.com/USA-English/Mot...duct_Guide.pdf
