h22a swap ECU error code 13
    my car is running a code 13 on 2 different ecus. i looked it up and its call a BARO senor i have no idea what that is. can anyone please help me figure this out thanks.
    http://www.cb7tuner.com/vbb/showthread.php?t=139263
    Isn't the BARO sensor inside the ECU? Strange you would have it on 2 difference ECU's though. If my memory serves me correctly, it is makes as a PA if you open up the ECU.
    I think I remember reading somewhere that the JDM ECU's did not have the sensor inside.... can you get your hands on a JDM ECU and try that?
    "There is nothing wrong with you that an expensive operation cannot prolong."
