anyone know what could of caused this.i painted my valve cover about 1k miles ago and my timing belt looked good.and i was going to re-paint it again and i find this.ruined my whole weekend
WTF! timming belt shredded
Did it not sound funny at all running?
Slamage is worth the Damage
Originally posted by crazymikey"Yes, we did officer. By the way, your eyes look a little glazed, did you just come from the donut shop?"
Check your tensioner. Go buy a new belt and put it on. While you're doing that check everything... After you have it on start it without the plastic covers on it and watch it to see if it's rubbing anything.
Originally posted by Hondalover View PostCheck your tensioner. Go buy a new belt and put it on. While you're doing that check everything... After you have it on start it without the plastic covers on it and watch it to see if it's rubbing anything.Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
That's just what I'd do. If you have a better alternative then let us know kind sir.
I know this is silly... but you didn't leave any of the grommets off that go under the valve cover nuts did you? I don't know what else would cause that?
Originally posted by Hondalover View PostThat's just what I'd do. If you have a better alternative then let us know kind sir.
Originally posted by 90CB7EURO View Posti noticed the valave cover had some black marks like the belt was rubbing on the topOriginally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
Originally posted by dj_ender View PostI thought my idea was fairly apparent in my last post. Why would he pull the crank pulley AGAIN to take off the timing cover, to put it back on so he can start his car and look for rubbing? Only to pull the pulley AGAIN to put the timing cover back on? When it would be much simpler to rotate the engine by hand and listen....
Originally posted by Hondalover View PostNever knew it was so hard to un bolt the crank pulley... lol. Thanks for the advice now though. Before it was just criticism.Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
That shouldn't happen, are you using a valve cover gasket? Another place to look is under the timing cog on the crank, something might have fallen down there while you had the valve cover off, and rubbing on the belt.
Originally posted by S.W.A.T View Postits easy to pull it off if you have the key that fits in it. used it couple of times
with the key and they are pretty tight lol.
