my car just started this today. when i start my car in the morn, it takes a little effort....then if i start the car later when its cold and been driven barley like 1 minute....id start it, but then it shuts off...
if i start again its fine everytime ..later if i let it sit and not drive it, it will shut down again..
then the battery light comes on...
any ideas?
the book says:
loose or faulty electrical connections at dist coil or alternator
insufficient fuel reaching the fuel injectors
vacuum leak at the gasket between intake manifold and throttle body.
my battery is fine...it seems...it is only 3 years old on the die hard...but even though the battery may be low...it would be able to tell becuase it would stress starting, my car starts but then shuts down...
i tested the voltage, its at 12.5 and 13.8 when it starts...the drain goes down to about 10.5 when it starts then up to 13.8.
thanks fellas
any ideas?
the book says:
thanks fellas
