How to reset ABS light??
    hey guys. need a lil help here. few weeks ago my abs light came on, i red the code it said it was the front left abs sensor. i changed the sensor and now i need to clear the abs code. how do i do that? i tried pulling abs fuses , didnt work? help me out please.
    h23a3 cb7 turbo sold
    FS: 1 Piece JDM Headlghts blackhoused
    My Members Ride !
    New ride
    '07 GTI Mk5 6spd
    ok . i rest the light but myc code came back ABS blinked 4 times and then 2 times. does anyone know what the abs codes are?
    My Members Ride !
    New ride
    '07 GTI Mk5 6spd
      code 42
      i believe it is a wheel speed sensor but not sure which one i can check on monday at work.
        its the front left one . lol . i already replaced it and then reset the codes and it came back again, next thing ill do i guess is check wiring .
        My Members Ride !
        New ride
        '07 GTI Mk5 6spd
          How do you check the codes for the abs sensor. My light is on also.
            under ur glove compartment on the right side there is a little blue connector
            u pull it out and jumper it with a paper clip or w/e. then u put the key in ignition and turn it to the position before start 3 times and then u wait. the abs light will flash now. abs error codes are diff then ecu codes, you will first get a main code then a pause an then a SUB code. for example if there is a problem like mine i get code 4 which is ABS speed sensor and then i get sub code 2 which means its the front left one. lemme know which code u get and ill tell uwat it is.
            My Members Ride !
            New ride
            '07 GTI Mk5 6spd
              I bridged the connector and the abs light comes off and the check engine light comes on. Thats all it does.
                u gotta turn it on and off 3 times, to on position and ll the way back off
                My Members Ride !
                New ride
                '07 GTI Mk5 6spd
                  abs help
                  did you check your drive shaft and make sure that there is nothing in the abs ring also check the wiring
                    I just gave up on the light. I tried turning it on and off 3 times and still no abs light blinks. All I get is solid check engine and thats it abs stays off and when I remove the jumper it comes back on I am still on whats wrong with it
                      you have to pull the ABS fuse in the under-hood ABS fuse box for at least 10 seconds, this should clear all DTC's from the ABS control unit. If it recodes, then you still have a problem somewhere.
                      00 Jeep Grand Cherokee 4.7 V8 4X4
                      92 Honda Accord LX
                      95 Honda Civic CX
                        yeah the fuse labled b2 in abs fuse box
                        My Members Ride !
                        New ride
                        '07 GTI Mk5 6spd
                          Great thread & info guys
                          I didn't know this procedure until I read this. My ABS light was on since I had my cb7 (w/ f22a) for like 2+ yrs. Now that I did my h22 swap I'm getting more involved w/ the car and the light turned off by itself
                          If anything happens again I'll definitely keep this in mind ...
                          www.StreetLightz.com
