I can spin the idle screw all the way up or down and has no effect on idle speed. F22a6, and it acts as if it wants to cut off when i stop but it doesnt just sputters real bad.
Cant adjust my Idle
Just because it's new doesn't mean it can't be defective right out of the box. You can use a digital multimeter and test the resistance, it should be between 8-15 ohms, and stay constant. You can also remove the IACV, and hook up power to the plug and see if the plunger moves.Originally posted by 91@CCORD74 View Postthat was my guess, ima clean it tommorow but then thing is i just bought it brand new
But first we need to know if you're adjusting the idle properly first. Are you disconnecting the IACV plug before trying to adjust the idle? Is the CEL coming on when you unplug it? Does the idle change at all when you unplug it?Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
