About my very first rebuild
    Originally posted by Mishakol129 View Post
    "With God all things are possible".
    -State motto of the U.S. state of Ohio.
    you do realize that was in the bible before it was adopted as a motto for a state right?
    Also header
    C-3PO's MRT USDM yo!
      Overspray
      02 Crv
        Also header
        yeah i know. But does anyone wanna tell me if that ac pipe is dangerously close to the headers?
        “Speed has never killed anyone. Suddenly becoming stationary, that's what gets you.”
        ― Jeremy Clarkson
        Very first tear down and rebuild. vvv
        http://www.cb7tuner.com/vbb/showthread.php?t=193755"]http://www.cb7tuner.com/vbb/showthread.php?t=193755"]http://www.cb7tuner.com/vbb/showthread.php?t=193755
        Current Build, F23 block F22b dohc head:
        http://www.cb7tuner.com/vbb/showthread.php?t=203144
          Originally posted by SOHC-FTW View Post
          Overspray
          at least I covered up the brake fluid resurviour
          ― Jeremy Clarkson
            header
            I think you wrapped it weird.
            Edit: i think you should be good though, you got foil on the ac like an inch thick plus wrapped header and also looks like you did your radiator hose. think that's the reason its touching.
              Header
              its got 2 layers of wrap on it, a total of about 40 dollars. Plus its got silicone spray on it.
              Soo, is the AC pipe gonna get fried?
              ― Jeremy Clarkson
                LOL should have put a bit more effort into it, it would have looked alot better. Like i said before your car aslong as your happy thats all that counts.
                02 Crv
                  header
                  Because edit. And idk anything about silicone spray
                    The pipe is what i'm concerned about, its touching the headers. I'm not talking about the wrapped part but the bare metal part.
                    There was a AC heat shield for the stock ex mani. but that's of no use now.
                    ― Jeremy Clarkson
                      I don't understand this
                        Hes asking if the clearance between his header and ac is an issue.
                        OP if it ain't touching don't worry about it. To add header wrap is made to keep the heat in so your probably good there aswell.
                        02 Crv
                          In this pic you see a pipe. Its in the center of the pic. That is a AC pipe going directly to the AC compressor and at the same time slightly touching the headers,
                          ― Jeremy Clarkson
                            can't hear that sorry^^
                            This I can understand. Like I said before you basicly over killed it so dont worry about it.
                              thanks. Does anyone know how to find out for certain if your cylinder head cam gear is facing the "UP" position for the TDC engine stroke?
                              I am having issues finding it on my cylinder head, it seems that the actual head is not completely level (its slanted) and so the "UP"mark really isn't UP but kind of off set. The same goes for the lines on the sides, they aren't level with the ground they are level with the head (which is slanted).
                              That confuses me. How can I know for certain if the cyl. head is ready for TDC compression stroke?
                              ― Jeremy Clarkson
                                when the cam gear is facing up, you will see a mark at the edge of the gear, on the edge of the teeth, at 3 o clock and 9 o clock, THOSE are to be level with the head, the up arrow with be facing slightly towards the rear of the car.
