Hey guys i found oil caked all over the top of the transmission its leaking from the distributor... the oil is leaking between the head and the distributor not the distributor cap... I was wondering if there is an o-ring between the head and distributor or between the cap?? Can you replace the o-ring itself or am I going to have to replace the whole distributor?? Thanks
distributor oil leak?
MR : http://www.cb7tuner.com/vbb/showthre...ght=CB7+R3ason
Originally posted by quaidumyou being able to see four blocks down the road is resulting in someone not being able to see 5 feet in front of them
good job, just what the world needs more inconsiderate driversTags: None
thanks
Also what do y'all mean when you say mark it first what am I supposed to mark
Originally posted by CB7 R3ason View PostHey guys i found oil caked all over the top of the transmission its leaking from the distributor... the oil is leaking between the head and the distributor not the distributor cap... I was wondering if there is an o-ring between the head and distributor or between the cap?? Can you replace the o-ring itself or am I going to have to replace the whole distributor?? Thanks
Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
