ok so if im not mistaken and from the info i found here.
http://www.cb7tuner.com/vbb/showthread.php?t=60856
our whells at 46 off set
does this apply to the se wheels i have now?
also what is the width of the se wheels the chart does not say. are they 6.5?
i wanna run some 16*9 and im not sure what a good off set would be. i wont mind if i have to roll the fenders a little to make em fit.
the 18's you can see on the first page of my MRT was 18*8 i believe with a 45mm off set and they sat pretty nice, just barley fitting in the wheel well.
so say i get 16*9 with a 35 off set, ide have to do some fender rolling. correct? and is there a place i can calculate the tires size to run. i kinda wanna stretch them a little as im sure i will need to to make em fit.
thanks.
thanks.
