Hey,
95 accord, 5 speed, stock
I just acquired a 95 accord and I am having some problems with my idle. When the engine is cold it will idle about 1100 to 1400 rpm. As soon as it gets hot the rpm needle will sit right before the zero. I can rev no problem, but it will go close to 0 rpm (try to die) then back up to the same rpm location
I can drive the car will no problems (shifting each gear), but as soon as come to stop in (neutral or first gear) it will die. I have to restart to get going again.
-change/clean: iacv, fitv, fpr, egr, throttle body.
-No vaccum leaks
-When I tried to adjust the idle screw, it has no effect on the idle adjustment ( I hear the engine speeding up, but the rpm stays in the same location)
-engine temp is within normal operating temperature and fans turn on correctly
Any ideas?
-No vaccum leaks
Any ideas?
