How to add lucas addative to trans?
    okay guys so heres the problem, my transmission(5spd) is hard to shift sometimes so i bought some lucas transmission fluid for hard shifting. Anyways fast foward i drain out some tranny fluid then realize the lucas oil is soo thick i cant get it in the transmission.. put a tube on the end of the bottle and in the tranny and it gets stuck in the tube. i need help i cant figure out how to get it in there now
    Just use Honda mtf would ne my suggestion....if its too thick I don't think it will help with your hard to shift problem
    1991 Cappuccino Brown LX Coupe
    2013 Rallye Red Civic EX Coupe
      Well if your are sure you want to use it, heat it up a little first. It'll thin out.
      Personally, I would just use oem fluid.
      Originally posted by wed3k
      im a douchebag to people and i don't even own a lambo. whats your point? we, douchbags, come in all sorts of shapes and colours.
        Where can you get honda transmission fluid? Honda only?
          I think somewhere on the bottle it actually tells you to heat it up... but, just think... if it's that thick in the container... when your transmission cools off, it's going to thicken again... Do you really want to put that in your transmission?
          92 Honda Accord LX - Sold
          2005 Nissan Altima 2.5S - Sold
          2007 Dodge Charger SXT
            I really dont know to be honest my tranny just doesnt go into gear alot
              Sounds like it's a different issue.. I don't know much about transmissions but could be a synchro or something? I wouldn't put that lucas in there at all. that's just me.
              First things first, I would do a transmission flush and put new Honda MTF in it and go from there.
                Honda would be a good choice, or even Acura. I get my fluids at a shop that specializes in tuning hondas.
                  where do you get honda mtf from? i dont think honda will be open today i need it driving today, and yes i believe its the synchro as well
                    oh okay well again i need it going today, whats so special about honda mtf?
                      HONDA service manual calls for 10W30, 10W40, 20W40 or 30 with API SG or SF grade oil for manual transmission. Since you are up north, I would use 10W30 if it was me.
                      As for using that Lucas additive, I would say no.
                      A&P-IA
                        GM synchromesh. that shit is on point. it makes a failing transmission last a little longer.
                        COUPE K24
                          Really eh where do you get that from?
                            I have Acura mtf ...just use whatever you can get till you can get Honda mtf in there...(the proper weight oil of course)
                              chevrolet dealership. ~17$ a quart.
                              COUPE K24
