wtf??!!?
    wtf??!!?
    something is very wrong...
    when i use something electrical for example turning on my lights the car shakes... wut the hell is going on??? any explanations? please help!!!
    p.s. it doesnt shake like crazy its kinda like a shiver.
    also just to clear it up its when the engine is running. park, drive (im not sure bout reverse..)
    again plz help!!!
    The Car
    When your in idle and turn your headlight etc. does your idle go down?
      power draw.
      sounds like you either need a new alternator or battery. They're the most common solutions to that problem. I reccomend a higher ouput alternator even if you don't have any sort of high powered audio, the extra juice will keep you from having any sort of probelms like that. That's really the place to start.
      --JDM F22A--
      JDM schmeDM, these lights are DIY-DM.
        if i dont get a new alternator can this get any worse?
        The Car
          well, it really all depends on how bad the shaking is, but it's most likely because there's so much draw on your alternator that it's lowering the ammount of power you have for your spark and other things in your car. All of our cars will do it, even with a brand new alternator, but an alternator that's on it's way out will make it happen a bit worse. You should probably just look into getting a new alternator sooner then later. It's not that expensive, and pretty easy to replace yourself if you have a ratchet w/sockets and a screwdriver.
          --JDM F22A--
            mine has been like that for about 2 years, its an old car dude things like this happen, not too serious tho
              im gonna just wait till it dies then replace it myself
              the vibration is not that bad just a little nerve wrecking..
              thanks guys
              The Car
                bump.. bump!!!
                o crap i think i fucked up my driver side window!!!!
                i was checking my system so i had wires all over the place, my bro comes along and wants to hear it with the windows rolled up so the neighbors cant hear it, so he rolls my driver side window up with a wire runnig through it. i didnt notice when it happened
                but after i tried the roll down the window and it would only go half way then i tried to roll it up again and the top it out like 2-3 inches from where its suppose to go!!
                The Car
                  my car would do that shiver quiver whenever i would turn on the a/c. my friend (who was a honda/acura mechanic at the time) told me to check my front motor mount. sure enuff --cracked. try check your front motor mount. just my thought.
                    can someone show me a picture of their front motor mount?
                    -can anyone help me with my window problem??? /\
                    The Car
                      take a pic of ur fron motor mount and we'll look at it
                      as for the window, take the door panel off and see if there are wires wraped up in the crank or whatever it uses
                        ill take a pic of my window and my motor mount today.
                        The Car
                          A motor mount is the thing that mounts your motor its by the header
                          Dynamic racing
                          Look out for 4 point cb7 strut bars for dohc!!!
                          bleh... i just put like 5 ounces of vodka in a 12 oz cup of mango iced tea...
                            damn mick, you had some f'ed up grammar in that sentence.
                              haha i was tired haha i sounded like harold938
                              Dynamic racing
