I just recently replaced my alternator on my 92 and everything was running fine for about a day. The car would have a starter click and not start 80% of the time. I got by this work week by using the "back to the future" pop start to get me to and from work.
This morning I was able to look into my ground connections. I replaced my terminals with the alternator and redid the grounds at the same time as diagnosis to know it was the alternator. I took off the ground clip on the starter as I read on here and cleaned it up with a wire brush. I pulled back the 12v constant connector from the starter and saw it was on fingertight! No way it was making a good connection! Problem Solved right?
Not so much!
However while tightening down the old worn factory starter bolt snapped! Should I just buy a new starter? I think there might be enough thread to get on a thinner 12mm nut to at least get me to work in the meantime! I work long days and don't have a day off until Sunday! Is the thread able to be extracted from the starter? I need opinions. I don't really have the time or money for another week.
Thank you for your help!
Not so much!However while tightening down the old worn factory starter bolt snapped! Should I just buy a new starter? I think there might be enough thread to get on a thinner 12mm nut to at least get me to work in the meantime! I work long days and don't have a day off until Sunday! Is the thread able to be extracted from the starter? I need opinions. I don't really have the time or money for another week.
