Squeeking from exhaust sys
    Okay I've tried working on this by replacing the rubber mounts upfront and the two just behind where the cat is and there is no broken mounts ... It still makes a innoying squeeking when going over large speed bumps at like 5mph or even man holes in the road I have looked at the gap of the whole system and can't see where it's makeing contact
    Any ideas?
    Thanks
    Originally posted by evil_demon_01
    Do it once, do it right.
    Saving a dollar is not worth risking a life.
    Missing My
    White -91 LX Sedan - leather converted
    Mulberry 91 EX Sedan
    The project 92
    Any ideas?
    Thanks
    Is the rear brace attached to the header? How tight are the bolts that bolt the cat to the downpipe?
      I have not checked how tight the bolts are but the pipe feels secure all the way from the front by gently tugging at it which I was attempting to re re create the noise but I will see how tight that is is there a specific tightness I'm looking for? And yes I can tell there is a brace attached to it which I'm guessing is the rear brace
      Missing My
      The project 92
        They just need to be tight. Are you for sure its your exhaust that is squeaking?
          I am pretty sure ... When I shake it side to side it makes a sound close to what I'm hearing and I am almost positive that my car is running quiet after I fixed my front susp prob .... I will investigate the bolts tomarrow
          Missing My
          The project 92
            It turns out my exhaust piping where it turns in behind of the gas tank isn't centered I bent the heat sheild back a bit and its gone thanks for all the input DJ_Ender
            Missing My
            The project 92
              It turns out my exhaust piping where it turns in behind of the gas tank isn't centered I bent the heat sheild back a bit and its gone thanks for all the input !
              Good deal man.
