First, 2000 words:
Second: Vehicle is a 1991 Accord LX Coupe w/ H2A5 trans, and the cat has been [shittily] replace with a straight pipe.
Both of those baffles, the "floor heat baffle plate" and the "tank baffle plate" and are rusted out completely right there. If I had the exhaust off, I could probably straight rip those bolts out by hand. I'm trying to diagnose a front end suspension/steering noise, and the rattling exhaust isn't helping. Further, it appears there is a hanger on that bend, but no complementary hook on the body is to be found; does anyone know what's up with that?
I've read that I can remove these baffles without worry, so long as the exhaust is sufficiently mounted (mine is clearly not...) and maintains a good air gap with everything. But, as mentioned, my exhaust is not mounted well at all (but that just means the air gap is even bigger than it would be), and further, the cat has been deleted and I haven't had a chance to change it back since I've owned it. Would the lack of a cat cause concern for increased heat? Could I temporarily remove these shields, perhaps repair them, and then reinstall them at a later date, while driving without them for some time?
Thanks much!
Thanks much!
