is there a grounds on the intake manifold it self. cuz my injectors are not spraying gas in to the head. and when I check the Haynes book it said check the grounds on the manifold but I don't see a grounds there form the wire harness so I am asking do they have a grounds from the harness to the manifold my Injectors are Saturated not Peak Hold.....
intake manifold ground wire
The only ground attached to the manifold is the ECU ground, and it's actually attached to the t stat housing, which is bolted to the IM.Originally posted by djscoonf22A6 View Postis there a grounds on the intake manifold it self. cuz my injectors are not spraying gas in to the head. and when I check the Haynes book it said check the grounds on the manifold but I don't see a grounds there form the wire harness so I am asking do they have a grounds from the harness to the manifold my Injectors are Saturated not Peak Hold.....Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
