*Back HISTORY*
I've had a sever power steering leak for a while. Recently while doing 40kmh my engine rapidly dropped RPM and turned it self off. I managed to turn the car back on. In the parking lot my power steering pump belt was on fire I cut it off.
The pump is frozen.
Could the pump be repairable and do you think it is the source of the leak?
Where are common areas to check power steering leakage?
Any suggestions on powersteering dye to use?
The pump is frozen.
