would a 5 speed transmission from a 94 cd5 work with my f22a1? did those cars come with an a1 or a variant of it? or did they come with f22b's? its an LX also.
Transmission Question
The tranny will fit, you will need to do this, as it should have 5 stud bosses:
http://www.cb7tuner.com/vbb/showthread.php?t=74780
A 94 LX would have came w/ an F22B2 motor too. Also, your CB is a manual, right?
thanks dan! my cb is an auto. i know i have to weld a new bracket or something. i also cant find the parts list or the diy to save my lifeLast edited by 1993 CB7 LX; 12-02-2012, 11:07 PM.
You're welcome, glad I asked. IMO, the easiest off the shelf solution would the auto to manual swap mount made by ESP. Mine was $110 shipped, not bad at all. Other option is to use an OEM CB manual tranny mount w/ the manual tranny "frame" mount welded in the proper position. Also, the ESP mount uses the Prelude stud pattern and so do the CD accords, so moving the studs would not be necessary.
http://www.cb7tuner.com/vbb/showthread.php?t=156847
If you would like to run a neutral safety switch, cpmike posted a nice diagram awhile back too.
