Ok so I see about 50 posts for timing belt tension problems.
I have the factory service manual. It says rotate CCW 3 teeth then tighten. Well the bitch is still loose.
Is there some trick I have missed. i have done and redone this about 5 times and when I crank the car the belt is loose on the Power steering side, but i get a lot of "slap" from the firewall side when the engine is running.
Any pointers will be appreciated.
steve
steve
