I am going to be going to the junkyard tomorrow to hunt for a p12. I'm just unsure of exactly what tools i'm going to need. Can somebody please help me out? (wrench, sockets/sizes, ratchet, pliers etc) I was looking at the p12 and it did not specify the size of the bolts. Thanks!
removing ecu
yeaah i was thinking about that. and i have the a4. I'm not sure if i wanna go down that route though. For one thing, i don't have the experience to swap intake manifolds, or camshafts, and i don't think i would trust my self. Thats why i'm just looking for the p12. They actually had an a6 but it was missing the ecu. I would think about going down the h23 IM and a6 cam route if i could find a good DIY on camshaft removal and installment. So far i havent found anything though. If you could help me out i would greatly appreciate it! I can get the a6 cam for $11, and the IM and Plenum for around $50, then the pt6 (if i can find one) for $25. So in reality i guess i would be spending the same amount to go you're route as i would be if i were to just get the p12. Do you think i would make more power getting the IM, plenum, a6 camshaft and ecu than just installing the P12? Also, do i need to get the h23 throttle body? Or can i just use the f22s? I'm pretty sure the throttle bodies are $27. But i'm not sure if they would be include into the full IM or if i would actually have to buy it separately.Last edited by michael6593; 01-04-2013, 06:13 PM.
When I got my intake. I took the whole thing injectors TB and everything for $15.
To remove the camshaft is rather simple. But If you are unsure of your ability I would say don't do it.
Maybe start with adjusting the valves. and take a look around under the valve cover and see if it looks like something you want to do. There is a DIY on the lower plug seals. you could start there. Basically from that point you would need to do a timing belt change. Its not quite that simple but thats basically it. For the cam.
the intake is a little more.
Yes to the more power ? But at the expense of a lot more work.
steve
Damn thats a pretty good deal! But how would i remove the camshaft? I actually adjusted my valves last week, and it was a pretty cool experience! I feel like if i had pretty detailed instruction on how to remove the cam, i would feel confident in doing it. So would i have to remove the timing belt, and purchase a new one to get the cam out? Would i be able to replace the a4 cam with the a6 & leave my a4 IM?
www.helminc.com
I STRONGLY urge you to buy a Helm manual for your car. You want DIYs? They're all there.
