oil light is blinking
    i was coming around an on ramp kinda fast and the oil light came on and started flashing... i drove home turned off the engine and turned it back on and it never came back on until i hadto hit the breaks hard and then it came on a again and flashed.. did the same thing turned it off and didnt come back on.. but did it again when i went around a tight turn again.. whats up??? anyone..??
    check your oil level.. mine did it a few times when I would take sweeping left turns. after I changed the oil and made sure there was enough... hasnt had a problem.
      ok i thought that might be it but i was just making sure... i have to change my oil anyway.. thanx
        i thought it was primarily a pressure light
          Originally posted by fizzbob7
          low oil, low pressure
          but i have had my light flash/stay constant and then check the oil level to see that i am not even less than a quart low
          could that be a sign of a bad oil pump/oil pressure regulator?
            The light coming on going fast around the corner happens from time to time if the oil is starting to get a bit low and splashes around. The oil splashes to the side and doesn't get sucked up for a second or two causing temporary oil pressure loss so the sensor thinks there's no oil. The stock oil pan doesn't have baffles to prevent the oil from sloshing around.
              ime, i had 0 oil on dipstick and light still never came up. i immediately went to buy 1-2 quarts.
              hahahahah
