I'm pretty sure the light that lights up my two climate control knobs went out. All of my other dash lights work. How should I go about replacing these lights?
Climate control knobs light went out
pull both knobs straight out to come off. the face with the cold/hot fan pictures usually is easily taken off then the white piece pulls out. behind that theres the small bulb socket. tricky to get it in there.
or you could take off the dash bezel. un screw the control unit from the dash, unscrew the unit from the cable. then get to the same socket on the back. it twists out. easier to put the bulb in but you gotta do all the other stuff.
C-3PO's MRT USDM yo!
