Engine shakes when starting warm.
    Hello every one,
    I recently started to have this problem. I have not done any work recently.
    When ever the car is already warmed to operating temperature, after a short stop at the store, I restart the car and it vibrate/shakes, more in the engine bay then inside the cabin. After about 10 seconds or less it stops and seems to be normal again. The car does not stall and it could be driven normal. I checked plugs and wire no oil or any thing out of the ordinary. It does not do it once that 10 seconds after starting during the drive.
    I just wonder if any one experience this before and what was the cause. The otherwise is good other than the small leak in the PS pump which does not cause the fluid reservoir to go down. And other problem is the driver's front bearing which either of the problem seem to be that of the shake.
    I am thinking the IACV might be failing? I can't find one at the junkyard every time I go no matter if they have new cars coming in. So some one always take it before I get there.
    The car is 1990 Accord LX all stock sedan.
    If you need more info, just ask.
