Hey guys well my car(1993 accord EX) is getting no spark. I have replaced the distributor, the coil, the ignition switch, checked all the spark plugs. All those parts are good. The grounds are good also. What else could it be. I am stumped. The car is getting fuel just fine. I want to see if you guys can answer before i take it to a shop. Please help!! O and it cranks but doesnt start. There is also no CEL.
No Spark
^ just recently went through this. Mtnbikaah helped me troubleshoot.
Best way to tell is open the oil fill cap and look to see if the top portion of the motor is moving internally while someone else is cranking the car.
Such was the case for me, and I got lucky with no internal damage.
Good luck.
92 Honda Accord LX - Sold
2005 Nissan Altima 2.5S - Sold
2007 Dodge Charger SXT
Did you use all new parts when replacing them? Could still be a faulty part..
Have you checked for continuity for the ignitor which is located inside the distributor?
Just tossing out ideas. I had an ignitor go bad.92 Honda Accord LX - Sold
I have seen a snapped/broken camshaft, once, due to stuck valves. It was at JY.
That cylinder head had a lot of crap build up, suggesting neglected maintenance/oil change.
To OP,
I recommend full overhaul on cylinder head at least rather than just just throwing another camshaft.Last edited by oyajicool; 02-23-2013, 10:39 AM.A&P-IA
