I recently swapped my F22B dohc for a usdm H22A4 Type SH engine. it appears the engine was in good shape, head looked brand new. got it all hooked up and got it sorta running.
Problems-
1. Car WILL not idle. I have the 2 vacuum ports open to allow it to atleast idle on its own. if you plug them, the car usually dies.
2. No vtec. I wired everything. Knock sensor, solenoid, pressure switch, all to the ecu using pins. I know the wiring to the ecu is right. I'm not sure about the rest. I went to pull the vtec solenoid off to clean it, it was absolutely FULL of metal shavings. 100% stopped up. cleaned it all out, and went on another drive. still no vtec. car doesn't feel like its got much power.
3. The oil light is on at idle, but goes away anywhere off idle. I don't think its the OPSU. I have a spare, I might swap out tomorrow.
only 2 codes im getting are
15 with is ign output signal
22 vtec pressure switch
Car cranks up and runs pretty smooth I guess. No weird noises or anything. This shit is getting old now.. Does anybody have any insight on whats going on here? This is my first vtec motor, so I'm completely lost at what to do... :/
Problems-
