how do you wire one wire vtec?
    so i just did my h22 swap last weekend, into my 92 ex coupe. motor purrs like a kitten and runs strong but i cant get vtec to work.
    its a jdm h22a
    ecu is a chipped p06 with h22 base map.
    ive herd that you can have it work fine with the one wire, but i can decipher how to do it from what ive read on here. please help
    "Good judgement comes from experience,
    alot of that comes from bad judgment"
    You need pressure switch and solenoid I believe. Any CELS?
    '93 H22A 5SPD SE - MRT - DIY-Turbo Sizing
      yeah CEL 22
        I'm not completely sure what happened, but I just went from a P13 to a P72 today and I got the same code. SO I put the P13 back in and it happened again. So I switch back to the P72 and it went away and the car runs great. I would make sure you have a good connection with both of those wires.
          i only have the one wire to hook up to anything
            Somehow you have to wire the oil pressure switch into the vtec solenoid. I don't know how.
            But somebody else has it wired that way. I have mine set to ignore the vtec oil pressure switch.
            I think a lot of JDM h22 don't have a vtec oil pressure switch.
            Any pics?
            steve
              if you search google, you will find a MILLION threads about this.......
              COUPE K24
                i did that and it was a bunch of nonsense.
                i have a quick walk around video on youtube. but its useless.
                its just the solenoid with one wire coming from it.
                  sourced from google.
                  http://www.clubcivic.com/board/showthread.php?t=131958
                  COUPE K24
                    How did you have your vtec hardware removed from an ECU that didn't have it stock from Honda?
                    Or are you referring to the chip ignoring the vtec oil pressure switch?
                    If its the later it didn't work.
                    steve
                      thank you. i dont know why i couldnt find that. all i could find was people that had different problems and no answers and a bunch of deleted posts.. jumping it out was my next choice. thanks again
                        np
                        COUPE K24
