Ok guys I have a problems with my cooling system, a day ago I drove the car to the main city when I notice that my temp was going high, I replace the thermostat as I knew it was old so I did and now I still have an over heating problem, my fans are not coming on I did replace the radiator fan time control unit as when I open the box it was burn but I still have it, I jumped the wires on the thremostaht sensor and the fans work so I replace the sensor and it still the same, when I drive I'm driving the temp keeps at normal but as soon as I slow down the temp goes high and when the car idles the fans don't come on at all and the temp is almost all the way up I don't want to burn out the engine as it still under 200K and I'm not ready to do a swap any ideas
overheating
check and confirm both hoses are hot when the car is over heating. If its not then you can still have a bad thermostat or air in the system.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
are they both the same temp? Do you feel that there is water in the top one?
Replace the radiator cap latley?What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
I've had this problem before on my cd. I had air in my system. Make sure you bleed all the air out of there cause it well give you the overheating problems that you speak of.
Here are the two links on bleeding air out the cooling
http://www.youtube.com/watch?v=hUzOTnsWImI
http://www.youtube.com/watch?v=zUpXgAJ1gjULast edited by cpl hero; 04-06-2013, 12:09 PM."Wise people treasure knowledge, but the babbling of a fool invites disaster" Proverbs 10:14
