So I have some strange starting problems going on...
Car wouldn't start the other day, solenoid would click but no starter motor action. It did this before weeks ago until after a few tries it worked. I figured now it died finally, it's 22 years old. So I ordered a new one.
I DO have battery problems as I leave this car sit and have to charge or jump start the car usually. I think I neglected the battery too much, even though it's only one year old, but listen to the rest...
So I install a new starter and use my jumper pack to try and start and no go. NO clicking, nothing. I jump it with another car and add a direct ground wire from starter to battery, clean up some other grounds, and it turns maybe one revolution and seems to draw all the available power. It turns like a very weak battery would. So I try bypassing the battery in the Accord completely-same result. I take belts off Alt and P/S and they spin freely. Jack up car and engine rotates. Take out the starter and try to make it run from jumper cables and it doesn't spin. So I figured I got a bad remanufactured starter. I didn't test this one before I put it in the car.
Autozone looks at it and it does run on their machine but he says it didn't look good. Another one we test before I leave actually fails their tests. So I get another one from another store which we test before I leave and it seems to work strong. Gear pops out immediately. Go home and install this other one and get the same results, initially...It eventually turns over and runs and we leave it running for 5 minutes. This is without having a battery in my car and I removed the extra ground strap from before. Turn it off and it won't start again and barely turns over. Cranking is very weak and struggles. I never checked my old starter to really see if it was dead.
So to recap...finally got car started, but never with a strong crank. Car ran, but would still have problems starting when trying again. Is getting good power from a jump car, grounds work, nothing is seized in engine or accessory pulleys. How can a starter test fine out of the engine with no load on it and have problems turning a car over, that was just running, getting 14 volts and good grounds?
The only abnormal thing right now is I'm not starting it with a good battery in MY car. But whatever right, that's why jumping works. I've started the car plenty of times with my dead battery.
