A/C questions! Does a cd5 r134 compressor work better for a retrofit?
    Hey everyone, I went to get my a/c charged on my already "retrofitted" Accord and was told that there is a hole in my condenser, and my compressor is leaking. Either way, I will be filling my Accord with r134a, as I purchased a voucher for it.
    It's getting hot and I want the COLDEST A/C possible, without using r12. I've owned a few cbs, and only one had an absolutely amazing A/C. I know it's possible. The others were pitiful, even after being recently serviced.
    So, my question is, will I achieve colder vent temperatures by using the cd5's A/C compressor? CD5s came factory equipped with r134, so does this mean that the compressor will handle r134 better, or will cleaning out the oil and using a cb compressor work just as effectively? I'm not sure if there are any differences internally between the two..
    From what I have read, the fittings on the top for the high and low side to the compressor may be different, but you can swap the top plate so that I can keep my current lines with that compressor.
    But, what if it were possible to carry over most, if not the whole a/c system from the cd5 over? I spent lots of time in the junk yard inspecting it and the compressor looks to be the same, but the condenser is very very different.
    Also, there's a thread on here that mentions adjusting your expansion valve with a hex! What's the best possible way to get the best temperatures?
    I was thinking a cd5 compressor with either a cd5 high pressure line, or a cd5 compressor with a cb top plate and existing lines, with the cd's expansion valve and seeing if it's possible to swap in the cd condenser? Doesn't this effectively make this entirely a cd5 r134 full system then?!
    Of course, the dryer will be changed as well.
    Anyone have any thoughts?
    Thanks!
    There were both Hadsys and Denso compressors for each generation so please specify what you have. I my experience with a Hadsys, I'm running a compressor out of a '94 Accord EX that had a Hadsys RC17D. My Accord came with a Hadsys RC17S. The only difference was the end cap and how a line attached to it and an extra rib on the pulley of the newer one. I got this one because my compressor had "Black Death", not because I wanted to upgrade. It isn't an upgrade.
    Your best bet, should you want to go through the trouble, would be to put a '98-'02 condenser in the car. Custom lines would have to be made. That design is much better than the one in the car right now.
      Other thing to consider when trying to get A/C blow cold air is heater valve.
      My heater valve was in closed position but allowing hot coolant to flow through, heating up the heater core. This made A/C blow not so cold air.
      After changing the valve, A/C is blowing noticeably colder air than before.
      A&P-IA
