I doing F22A1 rebuild. Since someone used thread lock on rod bolts, I had to pound them off. I may have damaged bearings by doing so. Now I am thinking of changing all bearings.
I am going through Haynes manual and OEM manual spec sheets. But, I cannot make connection between color coding and actual measurement/thickness of bearings.
Quick googling gave me this;
Above information is extracted from a Prelude forum (3rd gen), B series engines.
My question is do these numbers apply to F series engines?
If not, does anyone has a chart for bearing colors and thickness?
CHART COLOR to BEARING THICKNESS
Main Bearing Thickness By Color
Blue 2.013-2.010 mm 0.0793”- 0.0791”
Black 2.010-2.007 mm 0.0791”- 0.0790”
Brown 2.007-2.004 mm 0.0790”- 0.0789”
Green 2.004-2.001 mm 0.0789”- 0.0788”
Yellow 2.001-1.998 mm 0.0788”- 0.0787”
Pink 1.998-1.995 mm 0.0787”- 0.0785”
Red 1.995-1.992 mm 0.0785”- 0.0783”
Rod Bearing Thickness By Color
Blue 1.510-1.507 mm 0.0594”- 0.0593”
Black 1.507-1.504 mm 0.0593”- 0.0592”
Brown 1.504-1.501 mm 0.0592”- 0.0591”
Green 1.501-1.498 mm 0.0591”- 0.0590”
Yellow 1.498-1.495 mm 0.0590”- 0.0589”
Pink 1.495-1.492 mm 0.0589”- 0.0587”
Red 1.492-1.489 mm 0.0587”- 0.0586”
